1999 F350 Diesel/HVAC Problems
Old 09-11-2005 | 05:17 PM
bburt2's Avatar
Default 1999 F350 Diesel/HVAC Problems
Can anyone help?!! Back last winter I noticed that we could not get heat to come on at times and this summer the air conditioning seems to be changing to heat at times by itself and then back to AC. I have checked freon level and pressures, compressor clutch operation, fan clutch for proper operation and all have seemed to be correct. I think it is going to heat because the air temp changes to very cold to very hot and then back to cold again. Is there a control module or blend air door module that could be creating this problem? We have noticed that it has gotten progressively worse during this summer or should I say more frequent!
Old 09-11-2005 | 06:40 PM
cctxfish's Avatar
Default RE: 1999 F350 Diesel/HVAC Problems
check this out, it might be the same problem you are having:
http://www.blenddoorfix.netfirms.com/
theunpaidBill
01-05-2014 08:26 PM
tb30570
07-09-2012 09:17 AM
Hetron
10-14-2010 12:12 PM
PJMZ28
08-10-2007 09:23 PM
SNKPWR
11-11-2005 03:09 PM
Quick Reply: 1999 F350 Diesel/HVAC Problems
