2000 ford focus starting problem
Old 12-20-2005 | 02:53 AM
Roanbadger's Avatar
Default 2000 ford focus starting problem
I have a 2000 ford focus that will not start when cold outside. The engine will turn over and start for about a second then die. It will do this as many times as I try to start it. But it will start fine on warm days. I have changed both o2 sensors, changed the fuel filter and the fuel pressure seems to be fine but I still have the same problem. Any suggestions. I am at a loss.
Old 12-20-2005 | 04:40 PM
edaddik's Avatar
Default RE: 2000 ford focus starting problem
u know what i did. i have a eclipse 1990 model. in the morning i try to start it right. it turns and idle for 2 seconds and die. what i did i adjusted the throttle body screw and hit atleast 1500 rpm when you start it. it should start and be fine. also what i did is i cleand the throttle body by a carb cleaner or any trhottle body cleaner. and you know what it started like brand new. u should try it.
ytz1115
06-04-2009 03:27 PM
bob walls
03-16-2008 05:42 PM
steveaj
01-04-2008 10:24 PM
bgslck
07-04-2007 09:10 PM
bwilson3
10-09-2005 03:41 PM
