2005 F350 factory Toggle Switch help needed
Old 08-11-2008 | 11:17 PM
Country Man's Avatar
Default 2005 F350 factory Toggle Switch help needed
I have a 2005 F350 with the factory installed toggle switches and brake controler. Does anyone know where the wires from the four switches go to hook up auxiliary equipment??!! I would think there would be relays under the hood the run to that I could plug leads into. I want to hard wire a fuel tank in the box and also a snow plow but cant track where the wires end up. Any help would be great, Thanks!!
Old 08-12-2008 | 12:31 AM
Default RE: 2005 F350 factory Toggle Switch help needed
There's 4 blunt cut wiresbehind the CJB fuse panel.. (Central Junction Box) tapped to the wire harness.. Go to this site,,, https://www.fleet.ford.com/truckbbas/topics/qvmp.html
Bulletin Q-117 for the PDF instruction for upfitter control
Txscnc Engner
07-12-2013 06:08 PM
IDAHO_RICK
05-31-2010 09:22 AM
mawwam
05-18-2009 06:05 AM
gonzo
06-14-2005 11:41 PM
gonzo
North East
06-06-2005 01:09 PM
