2007 Ford Taurus A/C
Old 08-12-2008 | 06:13 AM
hfb1957's Avatar
Default 2007 Ford Taurus A/C
I have a 2007 Taurus and the air conditioner just stopped cooling. The clutch isn't engaging on the compressor. I checked all the fuses and they are good. Someone said it may be the cycling switch. Where is it located and could this be the problem. The switch on the dash seems to be working ok, since it will change from cooling to heating. Thanks for any help.
Old 08-12-2008 | 10:49 AM
andry's Avatar
Default RE: 2007 Ford Taurus A/C
the air conditioner still work, right? just stop cooling? if yes, please check the freon.
Old 08-12-2008 | 03:28 PM
hfb1957's Avatar
THe compressor clutch will not engage. It doesn't even seem to be trying to engage. The blower works and the switch will change from a/c to max ok and to heat but it won't start the comp. clutch. Maybe this info will help.
Old 08-13-2008 | 09:36 AM
Use Common Sense's Avatar
Could be low on charge (leak), bad LOW pressure switch, bad HIGH pressure switch, cooling fan(s) not engaging when in the A/C mode or a dead compressor clutch assembly. Being a 2007, is it under the 3 year/36,000 mile interval? If so, take it to a Dealer.
DuB71
06-19-2013 06:50 PM
RodRiv0410
03-27-2012 05:34 PM
hfb1957
09-02-2009 10:25 AM
hfb1957
08-17-2009 02:06 PM
kbenson
01-10-2008 05:43 AM
Quick Reply: 2007 Ford Taurus A/C
