2007 Taurus Transmission range sensor
I have discovered that my TRS has been causing my radio to cut out. I removed the fuse to the RCU and fixed the problem. Now my question is this, What else is routed through the TRS that could cause problems. I will be replacing the TRS but I have a code p1235 Fuel pump control module out of range. Is there any way that this could be related to a bad TRS also. I just dont want to buy a control module and then find out that it was something else. My TRS has 11 wires coming out of it so I bet there is something else that can be affected. Thanks in advance. Henry
