2008 5.4 high idle in park
Old 06-23-2022 | 09:27 AM
rubles23's Avatar
Default 2008 5.4 high idle in park
I have a 2008 5.4 Lincoln Navigator that Idles around 2000/2100 when in park or neutral.
Its has been sitting for almost 3 years with transmission problems. I finally put a used transmission in and seems to be all good except the high idle. It runs and drives fine down the road and when in gear it idles around 800/900.
Could the used transmission be causing the high idle issue?? No codes come up.
I have checked and found no vacuum leaks.
I got the Autel MP808TS scanner and its saying the desired rpm is 2000.
What tells the computer to set the desired to 2000? I have seen a few videos about a relearn on the throttle body but not having any luck getting it to change. Any ideas?
Old 06-23-2022 | 10:16 AM
I would suggest you double check that desired idle speed with a reliable source, something doesn't make sense there.
Old 06-23-2022 | 10:42 AM
rubles23's Avatar
What would you suggest? I have got the same thing from 2 different scanners.
You can watch the desired speed go from 2000 in park to 800 in rev and drive. Im lost
Old 06-23-2022 | 06:32 PM
I could be wrong, but the spec is coming from the PCM which I believe has a problem and the electronic throttle body is responding to the instructions it is receiving from the PCM.
Old 06-24-2022 | 08:01 AM
rubles23's Avatar
I was told the PCM needed re-flashed... so just dropped it off and will report the results later
Old 07-10-2022 | 08:30 AM
dmckenzie's Avatar
What art the short term fuel trims showing at idle?
LeeArnoldSystem
01-22-2021 04:20 PM
scottparker
12-31-2012 02:06 PM
RonFromPa
03-31-2012 10:15 PM
Beastly350
09-28-2007 11:18 AM
Quick Reply: 2008 5.4 high idle in park
