4:30 rear end
Old 05-02-2007 | 01:23 AM
cwj's Avatar
cwj
Default 4:30 rear end
I recently bought a used 2005 F-350 dually diesel. It has a 4:30 rear end. Can I swap out the ring and pinion for a 3:73? If so, how, or should I take it to a shop?
CWJ
Old 05-03-2007 | 05:23 PM
Use Common Sense's Avatar
Default RE: 4:30 rear end
I believe that the 3.73 is a 10.5" ring gear and the 4.30 is a 11.25" ring gear. Not sure if the housing is the same size as the 10.5" is a DANA 70 and the 11.25" is a DANA 80. You'll also need to check axle spine count. Might be easier and cost effective to just go to a bone yard for a new wreck.
hardbalance
04-12-2015 09:48 PM
d.rich
10-10-2014 01:23 PM
escaped-eric
12-23-2012 02:33 PM
CaptJack101
03-12-2008 01:30 AM
POOPSHOOTER
09-26-2005 01:32 AM
