7.3 Glow Plug Problem
Old 02-23-2008 | 11:12 PM
Tater50's Avatar
Default 7.3 Glow Plug Problem
1990 E350 168K: when turning switch on; glow plug solenoid (I guess that is what it is called; mounted on aft end of engine) clicks on, then 2 seconds later clicks off.
The only way engine will start is if I turn on & off about 15 times (each time holding for about 2 seconds).
any ideas?
Old 02-26-2008 | 08:26 PM
BRETM's Avatar
Default RE: 7.3 Glow Plug Problem
possible needs a new relay
Old 02-28-2008 | 05:54 AM
Tater50's Avatar
Did not want to buy one & install if that was not the case; becauseinstalled electrical products are not returnable.
Thanks Tater
Old 03-29-2008 | 08:51 PM
Tater50's Avatar
Right on: glow plug (solenoid type) relay. $150 from Ford, so I went to the recycle yard & got one for $35.00; cleared up the problem. Thanks for the input.
stripmechanic
04-06-2015 10:22 PM
indigoshaman
10-14-2012 07:13 PM
becksbikes415
07-27-2011 08:24 PM
indigoshaman
01-29-2011 11:03 PM
blixx003
09-10-2005 08:33 PM
