73 ford 460 problem
Old 07-29-2011 | 08:53 PM
kevineckols's Avatar
Default 73 ford 460 problem
I have a 73 ford ltd with a 460 in it i have had the car for a couple of years and just now really starting to work on it i have replaced the timing chain and set top dead center and set the distributor at the #1 piston and it seems like every time i get on the gas it jerks and lurches its not smooth and suggestions?
Old 07-30-2011 | 09:39 AM
Some engines had different positions for the timing marks. Are you sure you have the correct positioning for the marks? Also did you have the #1 piston at the compression stroke when installing and setting the distributor?
Old 07-31-2011 | 07:54 AM
Yes i had the #1 piston in compression i talked to a buddy of mine and i missed a step in the whole process and its alot better than it was now i just have to fine tune it i appreciate the help
drybasement
10-19-2013 09:00 PM
rscottmoses
07-29-2011 07:50 AM
tbucketflyer
07-30-2009 06:53 PM
slewis9910
08-26-2008 01:07 AM
72torino
03-21-2006 04:49 AM
Quick Reply: 73 ford 460 problem
