78 F-250 Blinker Problem
Old 04-03-2015 | 02:54 PM
joancasti's Avatar
Default 78 F-250 Blinker Problem
I have a 78 Ford F-250 with a puzzling blinker/headlight/brake light problem. I don't remember when the problem started but it has been going on for 2 or 3 months now. Today I have put in a new headlight switch, new break pedal switch, checked all the fuses, cleaned all the grounds, checked the bulbs( all bulbs work and are the correct bulbs),and flashers and looked for any broken or shorted wires. No trailer hookup or wiring for it. Everything has been checked accept the steering colum. The problem is this:
Everything works fine as it should until I turn on the headlights. With the headlights on the blinker lights on the dash glow and the blinkers do not work. With the lights on the right tail light goes off. With the lights on and I step on the break there is no right break light but the left break light works. Flashers work until I turn on the headlights.
Old 04-03-2015 | 03:40 PM
Might be a good idea to install a separate ground wire from the battery to a clean spot on the cab sheet metal. Either the socket for the R/S tail & stop lite has lost its ground or it might need one. Those sockets corrode internally and lose the connection to the ground wire.
If all of the above are good, could be problem with sig switch in column.
joancasti
03-20-2015 06:18 AM
dawsonmobley
08-25-2010 04:21 PM
woodrat
02-23-2008 09:29 PM
woodrat
02-23-2008 08:54 PM
wendywoo92
01-02-2008 01:19 PM
