86 ford f150 distributor
I am working on an 1986 f-150. I am getting juice threw the ground wire on the distributor. I have changed everything i can think of to include wirring harness. Can someone PLEASE HELP me with this problem.
Thanks John
Thanks John
RE: 86 ford f150 distributor
Depending on how far back you changed the wiring harness I would assume back to the fuse block, I would check the back og the fuse block itself to make sure you havent been shorting out and melting the block...If that is ok I would pull the connector at the brain inside the kickpanel and see if the harness is shorting there.
Hope it helps
Hope it helps
Cody Michael Krupienski
10-05-2012 02:18 AM
