87 F-250 front oil seal
How hard is it to change the front seal on an F-250 with a 300 ci six cylinder. I believe I can drop the oil pan and switch it out. Is that the best way to do it. Should I change the back one at the same time, or the oil pump while I am in there. Thanks
Which seal?? Is it the oil pan gasket, or the front crankshaft seal?? If it is the oil pan gasket, I would replace the entire gasket set. If the oil pump is original, it is your call if you want to change it. If it is the crankshaft seal, you can change that without removing the oil pan.
sumrbeachbum778
02-22-2008 09:25 PM
