91 Bronco AC System overhaul
Old 08-14-2007 | 02:12 PM
uamsstudent's Avatar
Default 91 Bronco AC System overhaul
My compressor and clutch must be replaced. I have already read that I will need a new drier if the system is opened. What other parts should I replace at the same time ? Evaporator ? Condenser ? Where should I buy them ? Should I convert to the new style of freon or stay with R-12 ? I want to do everything possible to make the AC system work perfectly. Price is not an issue. All suggestions will be appreciated. An experienced (but not perfect)mechanic will be assisting me during the repair process at his service station. He frequently utilizes O'reillys Auto Parts, but I am not opposed to paying extra for new Motorcraft parts.
Old 08-15-2007 | 12:17 AM
Use Common Sense's Avatar
Default RE: 91 Bronco AC System overhaul
Have the system completely flushed to get rid of any particulate contaminents, especially if your compressor died the "BLACK DEATH". Replace the drier, any rubber hosesand install a new orifice. It is not manditory to convert to R134A and converted systems tend to perform poorly. The R12 is more expensive, but well worth it. Evaporator and condensor should be OK. A new condensor may be in order if it's all pitted by stone chips and such. Better to change it now than later.
Tranny Frank
04-10-2011 08:07 PM
phenrichs
07-10-2009 09:37 AM
noonrock
01-13-2009 10:00 AM
jeffandteneka
02-16-2007 10:58 AM
Ralph the Wrench
04-15-2004 06:35 AM
