91 ford explorer, not firing
Old 07-10-2005 | 11:40 PM
missyl's Avatar
Default 91 ford explorer, not firing
I have a 91 ford explorer 4.0. i just rebuild an engine for it and got everything installed and hooked up, but i'm not getting any power from the battery to the ignition coil. I have triple checked all of my wiring and i have tested the connections and I cannot figure it out. I need help. does anyone have any ideas????
Old 07-12-2005 | 06:42 PM
hockeyhitman69's Avatar
Default RE: 91 ford explorer, not firing
if your battery is good check and make sure you reconnected the ground wire
Old 07-12-2005 | 07:13 PM
Ramrod48's Avatar
I know on the older ones they had a problem with the Postive battery cable, the cable would be loose inside the Terminal, sometimes u could pull or wiggle the cable at the battery terminal end an the ole girl would go to working. Act just like a DEAD BATTERY
Old 07-13-2005 | 01:52 PM
FRANKENSTEIN69's Avatar
I AM NOT SURE IF THE INERTIA SWITCH WOULD DISRUPT FIRING OR NOT, BUT ITS
SOMETHING TO THINK ABOUT.
GOOD LUCK
CHILAND
04-26-2009 05:29 PM
cowgirllaughs
03-10-2008 08:42 AM
gearhead1974
12-28-2007 12:48 PM
cleggett72
04-12-2007 03:20 AM
lizard
04-03-2006 12:58 PM
