93 Mustang 4cyl - Engine Light On
Old 03-01-2010 | 11:01 PM
missliss's Avatar
Question 93 Mustang 4cyl - Engine Light On
Yesterday, my cars check engine light came on. My friend came over with a scanner and it was throwing 6 different codes:
Key On Engine Off:
124, 223, and 224
Key On Engine Running:
412, 411, 538
We found a list of codes, and 3 of them have to do with the car not being able to register RPMs at any level, the others we're kind of clueless on. Pretty sure I have to replace the Throttle Position Sensor, but that is about as far as our research lead us.
Any help would be greatly appreciated!!
Old 03-02-2010 | 02:02 PM
Mary_Smith's Avatar
Why don't you take it somewhere where they read codes for free just to see what they come up with?
Old 03-11-2010 | 12:09 AM
blueovalguy's Avatar
Go to Auto Zone and have them check it. They can give you a print out of whats the mostly likley cause of of your problems are.
Old 03-11-2010 | 08:25 AM
Use Common Sense's Avatar
124 (Memory code) = TP voltage was higher than expected - Fuel control
223 (Memory code) = Dual Plug (DPI), SPOUT or IDM circuit fault - Ignition Systems
224 (Memory code) = Failure in ignition coil primary circuit - Ignition Systems
411 (Key On Engine Run code) = Idle speed system not controlling idle properly (generally idle too high) - ISC
412 (Key On Engine Run code) = Idle speed system not controlling idle properly (generally idle too low) - ISC
538 (Key On Engine Run code) = System did not receive "goose" test - TESTS
I would check the Throttle Position sensor (Take DVM readings) and also check/clean the Idle Air Controller. Then clear the memory codes and start fresh to see what comes back.
sulup
02-22-2007 12:54 AM
PTT
12-14-2006 07:19 PM
treetopp87
09-14-2006 01:18 PM
bluegrasssboy
08-01-2006 07:02 PM
mack61747
07-17-2006 11:19 PM
