95 Sable with a shimmy in the front end
There seems to be a shimmy at about 63-70mph ... any one have issues with this?
There's also a thump sometimes (often times) when the breaks are applied.
Any help with these would be great.
RE: 95 Sable with a shimmy in the front end
Thunk when brakes are applied could be your strut rod bushing pockets in K frame. Ive seen these come loose and cause this noise upon brake application. If it is a repetitive thumping then you probably have warped brake rotors. Your shmmy could be tire balance, but if the steering wheel shakes ide to side during this it is probably a tire problem, rotate may fix this.if not to bad.
