95 T-Bird Where to Connect Electrical Accessory
Although I am working on a 95 T-Bird the answer is probably common to many models.
I am tired of having problems with the electric cooling fan circuit and want to switch the fan direct with an illuminated switch.
Where is the best place to tap into a fused and ignition-switched circuit?
Can I switch the cooling fan with a 20 amp switch or do I need a relay?
Any other tips appreciated. Thanks, John aka JayKay
