98 escort 2.0 no fuel
Old 04-02-2007 | 09:10 PM
goinstrong's Avatar
Default RE: 98 escort 2.0 no fuel
By the way shouldn't there be 12 volts coming out of the inertia switch to the pump?
  #12
Old 04-02-2007 | 10:58 PM
wheelsup68's Avatar
Your fuel pump always has 12 volts when the key is on. There is no pressure change thru the voltage suplied to the pump, it is controlled thru the fuel pressure regulator. As stated above the only down fall is not having a fuel cutoff in case of accident which none of the other big threee have anyway. Your fuel output is controlled thru drivers in the ECM, if I were you I'd be looking closer at that.
  #13
Old 04-04-2007 | 03:05 AM
goinstrong's Avatar
That's the other type - I omitted - a system that always pumps to full pressure and uses the regulator seperately. Actually it's probably more common than one electrically regulated.
90EscortSTH
03-27-2011 11:27 PM
jbrink
04-20-2007 11:14 AM
jbrink
04-12-2007 07:47 PM
jcbassmaster
12-22-2006 05:42 PM
larry220
01-12-2005 04:55 PM
