98 Mustang coupe power window armatures????
Not even sure if that's what they are called. BUT...
It's the levers / arms that lift and lower the window and has the motor at one end.
What are the arms called and where might I find a replacement cheap?
I've looked on Craig's which sucks because I can only search cities and not entire states or the country for them.
If I knew the exact name of the "ARMS" it would help.
I had a friend try spot welding some stainless to them tryign to support them. The metal is fatigued and it buckles and twists when in use.
THANKS IN ADVANCE!
Leda
THANKS IN ADVANCE!
Leda
FYI - it's called the window regulator assembly, also known as a window regulator mechanism. Not sure how to find one for that model year, other than perhaps an auto salvage yard. (I'm assuming you don't want to pay dealer service part prices!)
67_stang
10-09-2007 08:58 PM
