Aerostar won't engage in drive
Old 09-06-2005 | 01:11 PM
Dan71's Avatar
Default Aerostar won't engage in drive
(Sorry in wrong forum can this be moved to tech )Hi hope someone can help !! Recently I've had the plesure of correcting some nice work on my friends 94 plate 4wd aerostar that was left in rather a bad way by local spanish garage who felt vacuum pipes were not needed and only got in the way . Cut a very long story short the van will engage in reverse and only sometimes (very infrequently) D or 1&2 gears . I suspect that this may have something to do with the vacuum modulater but no fluid is leaking back up the pipe. The fluid level is too high at the moment . Would the fluid height make the differance of not engaging at all . When i collected the van it engaged all gears but the plug leads were connected up wrong and was only running on 4 cylinders also with out the transmissiom modulator pipe in place now runs very sweet but no go please any thoughts very much appreciated.
bill9iron
02-19-2010 09:46 AM
Roereker
08-22-2006 02:17 AM
benny1277
12-12-2005 05:11 AM
cubsbz
11-12-2005 07:39 PM
Dan71
09-06-2005 01:11 PM
