airbag question >?????
Old 03-18-2007 | 01:19 AM
xplosiveg06's Avatar
Default airbag question >?????
i was wondering, if i disconnect the airbag module (looks like an ECU) would it disable the airbags completely? My truck is lifted (95 f150) and my airbag light is flashing. when i went to kill the airbag light, the module now beeps non-stop when u turn on the vehicle. im scared the airbag is going to randomly deploy so i just want to disable it ? and help is appreciated. THANK
Old 03-18-2007 | 03:07 AM
Default RE: airbag question >?????
How did you try and 'kill' the system warning lamp? It might be a good idea to have the DTC's read prior to disabling the diagnostic monitor, although unplugging the monitor will disable the tone generator..
Old 03-18-2007 | 03:37 AM
im 99 percent sure it did the 2 then 5 flash.. i js killed the bulb and now its beeping, i was just wondering that if i disconnect the moniter will i still have a risk of the airbags randomly exploding ?
Old 03-18-2007 | 04:14 AM
The airbag won't deploy without the monitor connected.. But, the monitor also doesn't have memory capability for stored fault codes if powered down.. Handy to have pending codes for system diagnosis/repair.. But, you might try a battery disconnect to deplete the monitors backup power and see if the tone warning cancels with the bulb installed.. Although a fault/light would still be present,the system status should then be proved out with an air bag simulator in place during reactivation once the component fault is found and repaired..
Old 02-08-2008 | 04:39 PM
sandyrev@gmail.com's Avatar
If your car was in an accident then you will have to get your airbag control module reset. I had the same problem with my Ford and the dealer wanted $220 for the new module. I have sent my module towww.myairbags.com and they have reset my module for $55 with FREE shipping. I sent them my module and they had a fast 1 day turnaround and shipped it back to me and I had it back in a few days. I would recommend these guys to anyone. I have saved a lot of money !!! [/align]
henryts77
05-15-2014 12:04 PM
bdbctcg
02-03-2009 08:50 PM
pr0cess0r
10-16-2007 04:16 PM
butters417
04-02-2005 02:52 PM
butters417
03-20-2005 11:57 PM
