Any adviceto these codes?
RE: Any adviceto these codes?
P0411 refers to DTC P1411..
The secondary air injection system does not detect the presence of air in the exhaust when introduced by the secondary air injection system
Check for..
Electric AIR Pump
Hose from AIR pump leak
AIR bypass solenoid leak/blocked
Hose from AIR pump blocked
AIR bypass solenoid stuck open/closed
P1414
The secondary air injection system monitor circuit is high, indicating the electrical AIR pump is on although the electrical AIR pump was commanded off by the PCM.
Open AIR monitor circuit from the pump
AIR circuit short to power
Damaged solid state relay
Open AIR pump ground
Damaged AIR pump
Damaged PCM
Check for..
Electric AIR Pump
P1414
Damaged AIR pump
Damaged PCM
Micheal Steele
03-03-2015 03:35 AM
sethro
07-21-2005 10:25 PM
