Anyone have a chart?
Old 03-03-2020 | 12:22 AM
Cameron Alexander's Avatar
Default Anyone have a chart?
Anyone have a chart of the size bolts and drain plugs that for uses for all ford cars??? And of oil type and quarts required.
Old 03-03-2020 | 10:44 AM
Responded to the other thread you made as well..
But, Id suspect the service center you'll be working at would have a pretty comprehensive electronic data listing source and possibly paper copy for the older applications, or both..
Back in the day, there wasn't all that many variations for filters, oil types, drain plugs.
Today,, a bit more challenging, but most of the newer Ford products will have an oil weight indication on the engine/oil fill area. Owners manuals can be a source and will have the capacity/type info as well if available in the vehicle.
The filter, being the used filter would be removed,, a simple online check against the current filter number in hand should yield a wide range of aftermarket and OE options.
There are also online filter interchange programs that are quick at both specific applications and filter brand options..
Most newer engines don't run straight dino oil, most run syn blend 'or' is a better choice over dino where it is run, some full syn or can be an option.
With online search options, capacities and others are easily found. Charts, books/manuals, if available or supplied work, but the data sources are leaning to the electronic options...
After some time at your job, you probably will be very familiar what to grab and use in house...
kenora
11-20-2020 05:41 AM
Smoothboy2
10-10-2019 09:38 AM
Hamnut
05-26-2017 12:34 PM
Mary Childress Raines
11-26-2013 10:31 AM
bandit1948
10-02-2012 03:33 PM
Quick Reply: Anyone have a chart?
