Audio problem 2002 Explorer
I need to replace my Premium AM/FM Stereo In Dash Six CD Radio. I know I have to remove the black cover around the radio that sits with clips into the dash. Can somebody tell me where on the cover those cilps are located and how to remove that cover without braking any clips? Ones the cover removed are there any screws holding the radio?
You can reply directly to marmar1305@yahoo.com. Thanks. Marc
CD error
Mark, did the door on the player close, or is it still open. If open, then someone rushed the cd into it and it missed the internal 'tray'. with the door still open, you need to put a bend into the end of a straightened paper clip but only the thickness of the cd you are trying to remove. If you are as good a shot as I am, you will reach this tool inside and pull out your cd. If not, you will grab some internal thingy and wreck your deck! If you have the cd, it will come out with a light pull.
Good luck! I have done both!
nmbcatch21
09-22-2008 12:18 AM
