backfire through carby
Old 02-15-2005 | 08:40 AM
xy351windsor's Avatar
Default backfire through carby
hi i am in australia i have a 351 windsor i changed my sump gasket and pulled oil pump drive out , since putting all back together i have a misfire , the car is backfiring through the carby under load , the timing is set about 10 bftdc as it was before , but i just cant get rid of this misfire , the car still pulls ok but just slight popping through carby , i know i may have put the dizzy in a tooth out but have checked and reset timing with no1 at tdc any suggestions
[IMG]local://upfiles/868/50537220985A46B0A04E7FA1EB2C0494.jpg[/IMG]
Old 02-16-2005 | 11:58 PM
cctxfish's Avatar
Default RE: backfire through carby
Double check the firing order.
Maybe you have a bad intake valve?
1992f150
07-16-2014 01:07 AM
ac917x
04-17-2012 12:29 PM
GENUINE907
05-15-2007 04:28 AM
mashburn
09-19-2006 02:14 PM
brianforford
09-30-2005 01:34 AM
