Battery going dead
Old 06-15-2013 | 07:04 PM
Rusty Baker's Avatar
Buy a quick connect for the ground cable. I have a short in a van I seldom drive and can't find the short. So I just unhook the ground cable when it's parked. Only takes a couple seconds. That will give you time to find the problem. The quick connect was less than $10.
  #12
Old 06-17-2013 | 10:00 AM
dob111's Avatar
Default Thanks
Thanks hanky can't read amps with meter I have, guess I just have to disconnect battery every time till I get some extra cash to take it to shop.
  #13
Old 06-17-2013 | 04:49 PM
You give up too easily !!
Try a few sites or google , voltage drop testing.
It is not difficult and you will be surprised how easy it is.
You have the voltmeter , the vehicle and the time. No extra $ required.
All you do is check the voltage drop across each fuse.
If you are unsure of testing electrical problems this will help you a lot.
There is always the possibility the drain may not be protected by a fuse , but maybe a fusible link. Simple thing to check across all the fuses first especially those that provide constant power without the key being on. You can do it !!!
  #14
Old 06-18-2013 | 09:30 AM
hfb1957's Avatar
Don't know if this will help, but I had a 1985 Ranger and had the same trouble. My battery would die overnight too. It ended up being a bad ground on the alternator. I just ran a wire from the alternator mounting bolt to the chasis. It fixed the problem. Good luck!
Captain B
11
04-26-2023 01:07 PM
mikep43019
08-11-2014 10:48 AM
JimC
07-08-2011 02:33 PM
MustangMiMi
12-12-2007 01:47 PM
pugmug
04-15-2007 10:02 PM
Quick Reply: Battery going dead
