blown fuse in 5.0
Old 03-06-2006 | 02:14 PM
spmaster's Avatar
Default blown fuse in 5.0
need help. keeps blowing #9 fuse for brake lights when both the brake and clutch is depressed. have chenged both the brake pedal switch and multi function / turn signal switch.
Old 02-04-2007 | 05:20 PM
chriseng's Avatar
Default RE: blown fuse in 5.0
I'd look carefully at the wiring which came in close proximity to the clutch pedal mechanism. You'd get these symptoms if the clutch levers were pinching the wire to the brake lights. Clutch alone wouldn't blow the fuse because there's no power on the brake light circuit. Brake alone wouldn't blow the fuse because the clutch wasn't pinching the wire. A combination of pedals would apply power to the brake light while the clutch was pinching the wiring. Worth a check out.
windstar man
07-04-2007 12:37 AM
1997 blue expedition
12-12-2006 01:02 PM
shellie
01-14-2006 12:45 PM
shellie
01-14-2006 09:28 AM
ChaostheOmen
05-09-2005 04:13 PM
Quick Reply: blown fuse in 5.0
