Brake n ABS lights-Ford windstar
I have a 2001 Ford Windstar, the brake and abs lights have been going on intermittently for a a month now. Brake fluid is fine, my mechanic look and found no leaks. he replaced some switch on the master cylinder and it was fine for awhile n now the light is back on..... the brakes work fine, no problems
any ideas?????
RE: Brake n ABS lights-Ford windstar
Yea it was common for those sensor's on the bottom of the Master Cyl. to go bad back a few yrs ago ,, Not a whole lot else would lit up both ABS lite an the Red Brake lite in the dash , Did you check the E-brake switch as that will lite up the red lite also , An I had a faulty brake computher cause them both to lite up , possibly a faulty ground, I know on the older F series there was a small ground wire that went to the Rad. support bracket, If it failed it would lite up the system also , it was a small black wire by the battery.
that sensor was just replaced and the light was off for a few days, now back on intermittently. i will show your post to my mechanic and let him do some more research,but at this point, I may just leave it alone if the brakes are okay for now...
Thanks
Jessie
Thanks
Jessie
