brake pedal freezin up
Old 01-31-2008 | 11:22 PM
ksbs's Avatar
Default brake pedal freezin up
hi i got a 2003 ford escape ltd. and in these cold days once in a while when driving the brake freezes up. you press on the pedal and the pedal is hard as a rock so keep on pressing on it and it finally breaks free. i have taken it to one ford dealer and they say its to intermitent and can't seem to find the problem. has any body else had there brake pedal frozen up like this before? i am now taking it to another ford dealer and they said they will do a brake flush. and see what happens. so if this does not work do i wait till i get into an accident? any body with any suggestions???????
Old 02-01-2008 | 01:16 PM
TOMMY D's Avatar
Default RE: brake pedal freezin up
check your vacume to your booster make sure no air leaks. or mayby have your booster checked out. anyways i think its got to do with vacume somewhere.
Old 02-23-2008 | 06:32 PM
cars7070's Avatar
I agree with tommy D
Old 03-01-2008 | 03:57 PM
grease_monkey1965's Avatar
if it isnt the brake booster you might have a caliper freezing up
Old 03-02-2008 | 03:16 PM
b rabbit's Avatar
it might be a problem with you hydralic control unit you isolate hold solenoind may be binding i would suggest the flush, will proably fix it ! If it where your vacuum check at the booster you would still have brakes it just would get harder as you pushed it .
bigfoot805
01-06-2007 12:04 PM
ras3355
11-10-2006 09:22 PM
machesked
06-05-2006 01:04 PM
cope607
03-13-2006 04:56 PM
css
01-17-2006 02:15 AM
