Bulb replacement
RE: Bulb replacement
Remove the plastic trim around the instrument panel. Remove the lower panel under the steering column by your knees. There is a small red string that moves the gear indicator needle. You need to remove this from the hook. There is then a small black wheel that holds the string in place. Unscrew the little black wheel to remove the string. Then there are 4 bolts that hold the cluster in place, one on each corner. Pull cluster out and unplug wiring. Twist little bulb holder out and replace bulb. Reverse to install. The little black wheel is used to adjust the needle o show you are in the proper gear when shifter is moved. When you adjust it, place shifter in neutral and center the needle on the N. Good luck. Oh, the bulb size is a 194
