carb problem 84 mustang gt
Old 09-26-2006 | 05:53 PM
nettletond's Avatar
Default carb problem 84 mustang gt
i shut off my car now it won't start it has a good spark good fule pressure i even tried starting fluid but the spay would not go in the carb no suckion any one have this problem before
Old 09-27-2006 | 12:40 AM
sean08's Avatar
Default RE: carb problem 84 mustang gt
On a simiar case, my bro powersprayed the engine compartment but to no avail. Inspect if your injectors were firing. I recommend that you check the battery cable to the starter and your battery as well. Also check all your gounds(ground straps are properly connected).
Old 09-30-2006 | 02:25 AM
bomb/450rider04's Avatar
is the carb in good shape and how much is the battery producing because it may be on its last let as it needs alot of cranking amps
Old 10-01-2006 | 12:50 AM
shel67's Avatar
hi, i would test the engine timing, sounds like it could be the timing chain. i had a 289 ford that did the same thing, i shut it off and there was no way it was gonna start, static timing seemed ok, but when i cranked it over i got absolutely nowhere! i found the timing chain EXTREMELY STRETCHED!! (i used to own an 84 gt...great car and very FAST!!! good luck!
AF Barrs
05-21-2013 07:08 AM
AF Barrs
05-21-2013 06:53 AM
miamipammy
05-27-2007 05:40 AM
sideways4m
09-09-2005 08:05 PM
hicracer
01-27-2005 04:31 PM
