Cooling Fan issues
Old 05-07-2020 | 08:44 AM
Fordowner2356's Avatar
Default Cooling Fan issues
My engine cooling fan kicks on and off when the vehicle is started with remote start. Engine is not at temp ac and defrost is not on. Any suggestions? Just started doing this a couple months ago
Old 05-07-2020 | 02:41 PM
The better way to check this out would require a schematic diagram to show where and how power or ground is getting to the fan relay. Unless someone has had this exact problem , and there are no guarantees even if the result is the same , the cause could be different.
Was the coolant level checked?
Old 05-07-2020 | 06:53 PM
Default Issues Fixed
Welp I opened up the fuse box and found the fan fuse was missing. I guess high fan was kicking on to compensate for the low fan not working. Gonna have to call the dealer about that
Old 05-08-2020 | 04:22 AM
Thank you for the update.
v8vega383
07-24-2019 10:53 PM
kubbie
07-30-2012 09:34 PM
dang482001
06-29-2007 10:36 AM
brewcrew
07-09-2005 03:50 PM
schlepie
06-06-2005 11:50 AM
Quick Reply: Cooling Fan issues
