CRUISE CONTROL
CRUISE CONTROL
I JUST PURCHASED A 02 EXCURSION AND THE CRUISE WONT KICK IN I'VE LOOKED IN THE OWNERS MANUAL AND IT DOESNT SHOW A FUSE LOCATION FOR A FUSE HAVEN'T REALLY HAD TIME TO CHECK IT OUT BUT ALL INPUT WILL BE APPRECIATED THANKS
RE: CRUISE CONTROL
Did the Excursionhave the Cruise Control RECALL performed? If so, then check the wiring.
Ford's Cruise control RECALL:
Ford found that brake fluid coul leak through the cruise deactivation switch into the cruise system's electrical components and cause corrosion. Corrosion can cause a short and keep the cruise control from working, but in some cases it can lead to a higher flow of current that can overheat and cause a fire at the switch.
Fixing the Problem
The recallconsists of a wiring harness that will act as a circuit breaker between the cruise deactivation switch and cruise control mechanism. It will shut off the electrical current to the switch if the current flow is excessive.
Hope this helps.
Fixing the Problem
Hope this helps.
audioguy
11-21-2005 11:56 PM
