Cruise control
Cruise control
I have a 95 tbird 3.8 liter the cruise doesn't work the green light on the dash doesn't even come on i replaced the servo and checked the fuse which is good not sure what else to look at.
try the brake deactivation switch (yes, the recalled one) on the master clyinder; they were forever going bad.
Also, you can check these systems very simply with an ohmeter at the servo to see if all the inputs are right from the power, grounds, and switches.
If I remember correctly, this body style might have had the deac switch on the left frame, way down low, best seen looking up from underneath.
I could be wrong, so take it easy on the old man if I am.
audioguy
11-21-2005 11:56 PM
