diesel substitute
Old 01-07-2008 | 12:32 AM
grefra's Avatar
Default diesel substitute
question is I was told aviation fuel and transmission fluid can be used as a diesel substitue, True or not and does it cause any damage to diesel engines if mixed correctly?
Old 01-10-2008 | 12:14 PM
peanut2008's Avatar
Default RE: diesel substitute
I put in a quart of trans fluid in my fuel tank every now and then.I have been told it helps clean and lube injectors,but don`t know for sure.
Old 01-19-2008 | 03:58 PM
b rabbit's Avatar
BAD IDEA IF YOU CONTINUE YOU WE'LL HAVE TO REPLACE THE INJECTORS @ about 500 a piece , and it will clog your filters leading to loss of power .
Old 02-18-2008 | 03:00 PM
peanut2008's Avatar
I have done that for over 30 years with no problems,it adds lubrication that low sulfur diesel fuel loses.
windystar
08-27-2019 01:44 PM
glb2687
09-22-2014 08:59 AM
wannarace777
12-07-2005 03:44 PM
harleybadboy2
08-16-2005 05:22 PM
doctor
12-16-2004 08:17 AM
Quick Reply: diesel substitute
