Do I need oil change now?
Old 04-19-2021 | 08:36 PM
Ford Fusion Owner's Avatar
Default Do I need oil change now?
I have a 2016 Ford Fusion SE FWD. As of last Wednesday my car had 35,464 Miles on it. I got my last oil change from a dealership at Ford and the sticker says to service it on 2/1/21 and 38.401 mileage. Oil life was at 39%. Last oil change was at 33.401 miles. They put the Ford Motocraft synthetic blend last time.
Old 04-19-2021 | 09:35 PM
scott.butler4's Avatar
You can wait for the oil life to be closer to or at 0%.
The stickers are just increased mileage by 5000 miles, the oil life meter is based on computer inputs that a sticker cannot account for.
Personally I do change my oil at approx 5000 miles so its easy to keep track of.
Old 04-20-2021 | 05:10 AM
raski's Avatar
I would change it. 5K is good enough for a blend. A full synthetic will allow you to go further. I go by miles and do not pay much attention to OLM's. If you really want to know, get a report done on your oil sample. Draw a sample when you drain, then you will know exactly if you can go further between changes.
Old 04-20-2021 | 07:33 PM
The vehicles only gone 2000 miles since the last oil change though.
Are you asking if you need a oil change due to the date on the sticker?
The sticker machines usually add 5 months onto the current date, its just a guess since prepandemic the average vehicle was driven around 1000 miles a month, thus 5000 miles would likely be in 5 months time.
Oil does not need to be changed based on the date, enjoy your car and don't worry till your at the next 5000 mile interval
Old 04-21-2021 | 04:59 AM
raski's Avatar
You are correct. I must have had a cranial vapor lock and thought he had 5k miles accrued. With that said, I would surely run it for 5k miles which should be around 38k miles. I don't pay much attention to time but go by mileage.
Old 04-25-2021 | 06:46 PM
I was told its either 5K and/or 5 months. Whichever comes first. I ended up getting it. Ford Motocraft Synthetic blend.
Old 04-25-2021 | 06:47 PM
Ford Motocraft Synthetic blend is what Ford dealership uses.
Old 04-25-2021 | 07:08 PM
That is incorrect. At my dealer we have four different oil options.
1 - Cheapest oil change for $15-$20 uses Pennzoil low grade synthetic blend.
2 - Most popular is the $40 oil change/tire rotation which uses a mid level pennzoil synthetic blend.
3 - Ford warranty oil changes or special viscosity, uses actual Motorcraft oils 5w20 and 5w30 are synthetic blend, 0w20 and 5w50 are full synthetic.
4 - Most expensive is Mobil1 full synthetic oil offered are 5w20 and 5w30.
If you want Motorcraft oil you have to ask for it specifically and it will bump the price a good bit up from that advertised $20 oil change.
Old 04-26-2021 | 06:53 PM
I got Motocraft synthetic blend. Change after 5k and/or 5 months, whichever comes first.
Old 05-03-2021 | 06:00 PM
Any suggestions?
ForestCrush
08-04-2015 06:08 PM
Mark B
11-07-2014 05:57 PM
Fusion13
11-22-2013 02:49 PM
krktoday
02-24-2011 05:33 PM
adal12
01-08-2006 03:53 AM
Quick Reply: Do I need oil change now?
