Door lock problem
Old 04-14-2015 | 09:03 PM
pdrc's Avatar
Default Door lock problem
05 excursion with keypad on driver door.
When I lock the door using the inside door lock button on the drivers side it will lock all of the doors and then a second later unlock just the drivers door. It does not do it when I use the key fob to lock doors or when I lock the doors using the passenger side door lock. Does anyone know how to fix this?
Old 07-09-2021 | 10:22 AM
MatthewRamirez's Avatar
This must be the fault in the programming the key with the lock, contact an auto locksmith for resolving the issue.
Old 08-30-2021 | 09:31 AM
DavidWilson's Avatar
Check the inner wiring of the door, i am sure the problem must be there and it can be resolved easily without hiring a locksmith.
Old 08-30-2021 | 01:14 PM
You might try shooting a little WD40 into the lock assy and see if it makes any difference.
dslmech03
02-26-2019 06:04 PM
Tim Brandow jr
05-31-2010 07:38 PM
Old Style
01-07-2008 09:00 AM
Ice4551
08-30-2007 07:25 AM
cwalk
05-11-2006 05:42 PM
Quick Reply: Door lock problem
