Drain ports - 2000 Ford Explorer Limited - SUNROOF
HELP, Drain ports - 2000 Ford Explorer Limited - SUNROOF
Just found this site and thought someone could give me a hand.
Where are the drain ports for the sunroof on a Ford Explorer Limited.
Aren't there a couple up at the sunroof and some exits down on the body somewhere?
I've got some slow leaking into the headliner. I temporarily stop it by caulking the the perimeter of the roof with clear caulk but I'd like to fix it.
It probably has clogged drains - But where are they located?
Thanks for any help.
I believe the drains for the front 2 hoses go down through the cowl down the door pillar to the rocker panel on each side.
The rear 2 drain hoses go down the roof to behind the rear wheel just in front of the rear bumper.
There could be some variation among different models , but the general areas are the same.
2000 Ford Explorer Sunroof Leak
I thought it was clogged drains at front corners of sunroof, but poured water in and they seem to drain OK. Noticed plastic part on right side of wind deflector broken off, found adrift in cabin. Replaced, will have to be gorilla-glued, but stays in place when sunroof is closed and appears to hold sunroof more tightly closed. Also suspect parking uphill may keep drains from functioning adequately. Still checking!
dtholmanmax
03-25-2008 09:05 PM
