Econoline E250
RE: Econoline E250
The year is l996 E250. There was no spark and we changed out the modular and the distributor because the teeth on the distributor had been broke off. We installed another distributor and the van ran about ten miles and shut off again. Again the distributor's teeth are broke off.
Any suggestions
Any suggestions
RE: Econoline E250
What engine?
Either the cam is 'walking' causing damage, or the 'now' bad teeth on the cam are damaging the new distributor set.. A bad/dragging oil pump 'can' damage the distributor drive gear, but will 'usually' shear the distributor drive gear pin if severe.. Have you cranked the engine over to physically check the cam/distributor drive teeth?
Commanderhayes
07-27-2012 08:31 PM
normsan3287
09-29-2010 03:56 AM
