EL falcon. just changed diff, got problem
Hey,
Just pulled out my old diff which was buggerd, and slapped in one i bought.
The problem is that its shakes like ****, from about 0-50km it shakes and is good when it gets past there. When i put my foot down hard on take off, she goes sweet as drives like a charm, take my foot off and shaking. One thing that has changed is the gear ratio from
3.08:1 to 3.23:1
Could really use some advice.
Cheers evryone
Scott
3.08:1 to 3.23:1
Cheers evryone
Scott
RE: EL falcon. just changed diff, got problem
Gear ratio change won't cause your problem. Sounds more like bad U-Joint(s) or lost a counter weight off of the drive shaft. Double check the U-Joints and look for any spots that may look like a counter weight was spot welded on.
Bad/used lube would normally cause no noticable issue unless it's a posi-trac (it would normally groan on turns telling you to change the lube). No lube would end up causing a siezure which you would definately know bu not moving.
bmorrisj
10-06-2007 06:08 PM
