Engine Swap Question
Old 02-26-2012 | 06:23 PM
Danielle Harrison's Avatar
Default Engine Swap Question
Can I swap a 5.4 L engine from a 2007 Expedition into my 1997 Expedition that also has a 5.4L Engine ( bad head gasket ). Does everything match up? Im a girl so I dont know all the technical terms for it. I would apprecciate any help I could get on this.
Old 02-26-2012 | 06:50 PM
Lars(wi)'s Avatar
If the head gasket is the only concern,I'd replace the head gasket
Old 02-26-2012 | 07:26 PM
Its not the only problem just the biggest- this old engine has alot of miles on it and this new engine only has 25000
Old 02-26-2012 | 09:53 PM
greasemark's Avatar
Acutally, I believe it will. The thing to look for is if they look the same; the 2005 could be a 2 valve (which I don't think it was), and the 2007 is most likely a 3 valve; the valve covers should both be aluminum, if this is a direct swap.
The other thing to look for is the engine mounts size, shape, and attachement to the engine and body. They must match up.
I think this is a straight swap and should work well. You might have to change the intake manifold around from engine to engine, but it should be out for the exchange anyway.
Old 02-26-2012 | 09:59 PM
Richard7425's Avatar
If I am correct, I do not believe it will. The 07 I believe is the 3rd generation while the 97 is the 1st. that would mean at the very least the sensors are not going to communicate with the computer and likely the wiring harness will not match up. But I will do a little more research on that and get back if no one else posts a positive answer.
Old 02-27-2012 | 04:30 AM
Thank you so much, I would really appreciate that
Old 02-27-2012 | 08:23 PM
Sorry, but according to what i have found I must agree with Lars. The work involved in changing the 07 to fit the 97 is just not worth it. You could rebuild the 97 easier.
*Note: if you installed a block sealer or some form of stop leak, PLEASE have your coolant system flushed thoroughly.
Old 02-27-2012 | 09:17 PM
greasemark's Avatar
Oops, i misread it. I thought it was from an '07 to an '05. NO it WON'T work. I'll get my eyes checked.
SuperDirty77
03-10-2015 03:19 PM
Danielle Harrison
02-26-2012 06:05 PM
Harshard
05-12-2011 01:37 PM
bmwrocks03
04-21-2008 09:29 PM
Hockey Stud
05-03-2007 09:49 PM
Quick Reply: Engine Swap Question
