F 150 wont stay started
RE: F 150 wont stay started
I had the same problem.#1 change the EEC relay and the fuel pump relay. they are cheap and and just might fix it.
#2 clean and check the idle air control valve
#3 do not change the set screw on the throttle plate , it is pre set from ford.
good luck.
good luck.
yeppers try cleaning the throttle plates an cleaning the IAC like cctxfish suggested , thats usually the problem , there gummed up , just use some carb cleaner an a old tooth brush on the throttle plates an dont forget to clean the back side as well as the inner bore where the plates ride , on the IAC, just spray it let it sit a few minutes an spray it again , then go for test drive , your idle should be like close 900 rpm , it may be a lil hard to start at first till it swallows the carb cleaner so dont get worried
