fiesta MK4 doing my head in
Old 12-18-2012, 08:14 AM
mattcreate's Avatar
Just an update; thereīs no MAF sensor anywhere, Iīve taken one off a donor car but of course thereīs nowhere to plug it in . Strange the carīs been running fine for over a year without one. Iīve tried a replacement fuel pressure regulator-no difference.Also thereīs no engine warning light ( CEL/MIL).
  #12
Old 12-18-2012, 02:01 PM
bluewind's Avatar
I give up.
Did you buy a Haynes manual or similar? I buy one for any vehicle I have. I am convinced your car has been modified.
  #13
Old 12-18-2012, 03:18 PM
If it is as you state, I believe bluewind has made an excellent suggestion and that is do a compression test. That should tell you if there is any type problem with the timing belt and if so whether any damage has been done to the valve train. There are certain basics that need to be done before jumping to conclusions. Let us know what the results are from the compression test.
  #14
Old 12-18-2012, 03:30 PM
mattcreate's Avatar
Thanks again,your comments have been very useful. I īve found out that the later models of fiesta have the MAF sensor replaced by a MAP sensor on the rear of the manifold, so obviously I will be checking that. Still havenīt located the engine temp sensor.
  #15
Old 12-19-2012, 08:56 AM
bluewind's Avatar
ECT sensor : # 5 in the diagram.
bignick71
03-02-2014 08:17 AM
trev0006
06-05-2013 11:50 AM
mattcreate
05-22-2013 11:33 AM
STUFFSK825
09-07-2007 04:25 PM
daveranger
10-21-2006 03:27 PM
Quick Reply: fiesta MK4 doing my head in
