Ford 500 A.C Problem. Plz help
Old 10-04-2018 | 11:16 AM
Mattj62387's Avatar
I really do appreciate all the time and research you've done for me. When you say Instrument cluster you do mean (Tach, mph, odometer etc..) I am not dumb it's just such an odd thing to be relayed to the A.C not working. Lol. But I've read similar threads about the ICM. The climate control panel and the Instrument cluster are the ONLY 2 things NOT checked. Now that I know the color trace for the wire I will get into that later after work.
  #12
Old 10-04-2018 | 01:08 PM
Mattj62387's Avatar
I traced the TAN/BLACK wire from the Istrument cluster to the A.C control panel. I checked for continuity and it's good. Then I checked for voltage. In the Run/ON ignition position i get 10.41V from the ICM and the A.C CONTROL PANEL. As soon as I turn the A.C switch ON I loose voltage to only 0.02V.
  #13
Old 05-23-2019 | 12:05 PM
Mattj62387's Avatar
There is NO continuity between 85 and 3 on the relays. What does that mean?
  #14
Old 05-23-2019 | 12:11 PM
Mattj62387's Avatar
I am sorry there IS continuity between 85 and 3 when ON.
Mattj62387
12-13-2018 08:13 PM
Pjb
07-28-2018 02:48 PM
romeodz
07-12-2014 02:08 PM
meljudmic
10-11-2013 07:44 AM
highlander
08-08-2012 10:05 PM
Quick Reply: Ford 500 A.C Problem. Plz help
