ford bronco TFI
Old 01-13-2009 | 04:46 PM
dlanc88's Avatar
Default ford bronco TFI
anyone ever had trouble with the TFI module, what are the symptoms?
Old 01-13-2009 | 07:14 PM
way2old's Avatar
Default RE: ford bronco TFI
They are a known failure item. If they fail, they do not allow spark to go through the distributor. They usually fail when hot and may or may not start when it cools down. If you replace it, be sure to use the grease supplied with new part.
Old 01-13-2009 | 08:49 PM
Use Common Sense's Avatar
Also make sure both mating surfaces are totally clean as the grease is a heat-sink grease and needs a clean surface to transfer heat properly.
noonrock
01-13-2009 10:00 AM
Superfuss
02-29-2008 03:53 PM
cwbronc
07-12-2005 08:17 PM
x1spiderman1x
05-13-2005 02:43 AM
tomtom
02-28-2005 06:53 PM
