Ford Focus high fuel consumption
Old 04-20-2013 | 01:00 AM
vipercarcom's Avatar
Default Ford Focus high fuel consumption
Hello all i just buy a Ford Focus from 2008 the most beautiful car I had, model is manufactured in Europe. I have problem with fuel economy, my car consumes very much fuel litres/100 km or miles per gallon.
What to change first?
Old 04-21-2013 | 08:30 AM
bluewind's Avatar
How many kilometers are on the engine? Is there a check engine light on? Is the car running bad or normal other than the fuel consumption?
have a look at the air filter first. Knock it against something (a tire, maybe) and see how much dust comes out. If it is a lot of dust replace the filter.
Old 05-18-2013 | 03:55 AM
My engine has 130.000 km the car has no problem, no light on, no running bad.
I found a site where shows the real fuel consumption for Ford Focus 1.6 TDCi Ford Focus fuel consumption, miles per gallon or litres/ km | Cars Fuel Consumption hear they say that the Ford Focus with 1.6 engine TDCi fuel consumption with mixed drive it's 4.7 litres/100 km, my Ford Focus consumes how they say it would have to consume with city drive 6.3 litres/100 km.
Old 05-19-2013 | 12:45 PM
bluewind's Avatar
I had no idea you have a Diesel! i know nothing about Diesel except the first name: Rudolf.
Is your Turbo kicking in? the particulate Filter clogged?
Old 06-02-2013 | 01:09 PM
Turbo it's ok, I do not think it can influence the car fuel consumption, I asked about particulate Filter and understood this you can not change, just clean it.
Old 04-20-2024 | 06:31 PM
Motts0007's Avatar
Default High fuel concumption
I can't seem to get a straight answer......
I have a 2008 Ford Focus SE 2.0
It has 160000 kms on it.
I have changed spark plugs, Ignition coils Air filter Changed motor oil, Cleaned MAF, Throttle body.
.There is NO check Engine light ( tested with a basic OB2 scanner as well as upper class scanner
still no codes.
I put in 19 litres of regular fuel and got 172 kms in the city.
Just trying to figure out if mileage is good.
Polski
12-11-2008 07:45 AM
techford
11-16-2008 07:53 PM
techford
11-16-2008 07:46 PM
kb1fwe
09-14-2008 03:34 PM
rkjain514
02-11-2008 10:37 PM
Quick Reply: Ford Focus high fuel consumption
