Fuel pressure test 05 five hundred
#21
We know the PCM provides the ground for each of those , coils and injectors , to operate,,, so all you need to do to verify the PCM is providing a ground for those to function, is to connect a test light to a hot source (+) (battery+) and see if the other wire on the plug at the coil and injector is getting a ground from the PCM when cranking. If the light blinks, that means the ground is getting to the injectors/ coils. IF NOT, signal comes from PCM, so need to make sure PCM has good ground connection going to it .
#24
Thank you for reply. I have figured out how to hook up pressure gage. The reason why I want to check pressure because it will crank but no start sometime. It’s not at all the time so it’s difficult to find cause, I guess. I have replaced fuel pressure sensor, fuel pump, transfer pump, fuel filter.
#25
Hi skrz,
If you would,
because all vehicles are not the same , it is very important to know the year, model and engine size
Some require a scan tool to check pressure because a hi pressure fuel pump may be involved .
I always ask, why do you want certain info because if we see you could be on the wrong path, we might be able to help direct you to a better path.
If you would,
#26
2005 Ford Five Hundred, 145k miles, receiving code P0191. Other symptoms involve general sluggishness, especially when trying to reach highway speeds. My car will kind of "hang" at 45-50mph and RPMs will continue to climb. Have to let off the gas to get the car to shift to the next gear.
