Fuel pump circuit
Fuel pump circuit
I have and 88 Ford Ranger that wasn't running when I bought it. The problem is that the fuel pump won't come on. The signal that turns the relay on is not going low when I turn on the ignition switch. I can force it low with by grounding it and the truck will start and run. Is there a sensor that interlocks the fuel pump circuit? The EEC relay (whatever that is) is the same relay as the fuel pump and it's not turning on either. What am I missing?
jozepy24
07-13-2019 05:21 AM
fordexpedition2006
04-21-2017 05:23 PM
Beatty
08-12-2014 08:22 PM
