Help with wiring up a power inverter
Old 03-15-2008 | 07:32 PM
chemoman's Avatar
Default Help with wiring up a power inverter
I need to hook this thing up toan auxillary source. It uses 10 ga wire, so I'm guessing somewhere under the hood is my best bet.
Can anyone tell me where would be the best place without splicing? I'll splice if I have to, but would rather not.
Thanks for your input.
Old 03-15-2008 | 10:12 PM
grease_monkey1965's Avatar
Default RE: Help with wiring up a power inverter
if i were you i would wire it straight to the battery,what size inverter is it
Old 03-15-2008 | 10:56 PM
chemoman's Avatar
It's 400w two outlet.
Direct to the battery would be easiest, but I was hoping to not have to remember to turn it off every time.
Thanks
Old 03-15-2008 | 11:19 PM
Whats the application?
Old 03-16-2008 | 09:07 AM
chemoman's Avatar
I'm setting up a mobile office to run a lap top, printer and cell phone charger.
Any ideas???
Old 03-16-2008 | 03:28 PM
Why not just add a small constant duty solenoid under the hood, triggered by a 'KEY ON/ACC' source? Or a decent sized/rated relay.. The inverter and cable run should be as close to the battery source as possible to keep the signal clean..I occasionally run my laptop coupled with my cell charger off of a 150w inverterplugged into the power point and has worked fine... My GPSon the other hand,, is on a flexstand at my seat/console position,and 'was' tied into my seat power for a short convenience power tap.. Even without the seat in any kind of movement I was picking up a 'terrible' static when the GPS was playing music files into my OEM radio.. Moved the power source to the power point and it worked fine.. Point being, that tapping into another/shared source may/maynot affect functionallty.. Plus a more direct connect, should any more add in's be needed won't add any guess work to the system loads..
Old 03-16-2008 | 06:50 PM
chemoman's Avatar
I went straight to the battery for now. I'll have to add a relay later. I just don't trust myself to turn it off every evening.
As far as the GPS, I'll leave it in the power outlet at the dash. It all should work together well.
Thanks for all the ideas.
Old 03-17-2008 | 05:34 AM
Use Common Sense's Avatar
When using a relay in todays vehicles, make sure you use one with a diode installed in it. Like a BOSCH or FORD OEM unit. The diode eliminates the voltage spike which can damage the computer modules in any vehicle. A 12VDC relay cangenerate a voltage of 1,000 to 1,500 volts during turn-off. This voltage is duilt up in the energizing coil of the relay. With the advent of modern electronic systems, this relatively large voltage transient has created EMI, semiconductor breakdown, and CPU failures.
Old 03-17-2008 | 02:05 PM
Absolutely true..
When a relays coil voltage/mag fielddrops, an 'inductive kickback' can occur.. With a quenching diode the voltage kickback spike is stopped..
countymnca
12-06-2008 03:37 PM
strider380
03-15-2007 01:28 AM
strider380
01-24-2007 12:25 AM
tomt81
04-27-2006 12:43 AM
tomt81
11-02-2005 02:31 PM
Quick Reply: Help with wiring up a power inverter
