HID Install & DRL
HID Install & DRL
I have a 2013 Ford Taurus
It has the single 9005L+ bulb for high low and DRL
I have found out that a regular HID kit (9005) will work in the car
But I need to first find out what fuse runs the DRL
I looked in the manual but it does not say?
I need to have the DRL disconnected for my HID kit install and in past vehicle have just pulled the fuse
Be very careful with this; the DRL can be 'bypassed' without too much trouble, but there like 3 TSB'S that Ford put out concerning the amperage draw of aftermarket headlight devices that pull too much power through the stock headlamp switch and either melt or otherwise damage the connectors and switches. It might be best to have a relay in the HID system where the low side controls the relay, and the higher amp wiring is removed from the switch side. Since I quit Ford, I don't have acess to the website, but I've seen this before.
Just a word of warning.
I have a 2013 ford explorer xlt. I am trying to install HID that are 6K. I have tried to install it but lights flicker. I was told to get a relay harness or capacitors. I bought the capacitors and it works well but my question is, Is there any way to cancel or somehow turn off DRL so that i wont have my HID's on the whole time?
Thanks in advance!
Thanks in advance!
Kwizz
11-01-2009 04:57 PM
